Hi Sir,
My customer using bq25896 found EMI issue when charge active. (over 2dB, target is -4dB)
We try add snubber in SW pin but looks still fail.
Do you have idea how to reduce EMI?
Or do you have schematic for EMI solutions?
Thanks, Ian.
Hi Sir,
Thanks, Ian.
Hi Ian,
The snubber has to be tuned to each PCB layout using empirical measurements. Below is a link to an appnote I wrote for sizing RC snubber for a boost converter but the same concepts apply to the buck. Attached is a presentation on how to reduce EMI for BQ2589x family.
https://www.ti.com/lit/an/slva255/slva255.pdf
6254.bq2589xbq2419x_29xlayoutandEMIrecommendation.pdf
Jeff
