Part Number: TPS65721
My device is going fault state during charging, it is not consistent but it occurs in every ~50 charge cycles. it recovers back once i give a device reset and it is not repeating for next few days.
I am reading the charge state register and it gives 0x0E when it goes to the fault mode. also other register values are not responding, for example the charge status register does get updated when connected with the usb charger.
I couldn't find more information on fault mode other than that is given in the data sheet.
what is the correct way to exit from fault mode?
Is it happening because of some wrong configuration?
How can i make sure the device will not goto the fault mode?
