BQ40Z50-R2: How to judge the two consecutive 40-s periods of valid charge termination?
Part Number: BQ40Z50-R2
Other Parts Discussed in Thread: BQ40Z50
Hello Sir:
Our customer check the log data of their tested result that they find out the results cannot meet the two consecutive 40-s periods of valid charge termination.
The taper current set 230mA and charge term voltage set 100mV.
Based on the log file which has two termination results.
Please check these two results from attached file.
The first result shows when avg current is under 230mA the time is 10295.205s, then when charge status changed to 0x00C8 the time is 10373.658s, it means 78.453s of time interval.
The secondary result shows when avg current is under 230mA the time is 39920.796s, then when charge status changed to 0x00C8 the time is 39975.079s, it means 54.283s of time interval.
Please let me know why these two results cannot meet the two consecutive 40-s periods of valid charge termination?
Which parameters we need to check too?
CP202_R7_0.5C 0egC CK(A2803)_200618.rar
