UCC28C40-Q1: UCC28C40-Q1 DS Rev E vs D
Part Number: UCC28C40-Q1
My cutomer checked DS revision E versus D. The changes mentioned in the history can't be found.
Can you confirm the real changes that should have been found.
Changes from Revision D (October 2019) to Revision E Page
• Updated Available Options Table heading from TA to TA = TJ ............................................................................................... 3
• Updated Operating Junction Temperature in the Recommended Operating Conditions Table, from –55 to 150 to –40
to 105...................................................................................................................................................................................... 4
Harry711
  • Harry,
    Thanks for bring this to our attention. I downloaded the UCC28C40-Q1 data sheet. I see the Revision D to Revision E changes highlighted in section 4, but the changes are not found within the data sheet. I also do not understand why, but I will check into it and make sure the data sheet is modified appropriately.
    Steve M
  • Harry,
    I have brought this to the attention of our technical docs editor. TI is constantly striving to improve the quality of all our documentation. The data sheet should be corrected and on the web shortly. Thanks for your help reporting the issue.
    Steve M
