Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4What are the meanings of bus-powered and self-powered hub requirements in the data sheet TPS2075 ?
What is the power consumption for TPS2075?
If I only needed 1 of 4 Power switch output (Without using the 3.3-V internal voltage regulator output), what is the input power consumption need by TPS2075?
If I only needed 2 of 4 Power switch output (Without using the 3.3-V internal voltage regulator output), what is the input power consumption need by TPS2075?
