Other Parts Discussed in Thread: TPS546D24A
Hi TI,
There is currently a case where the configuration is Vin=3.3V, Vout=0.75V, Iout=18A. Does this material fit my configuration? Or have other suggestions?
(Need to monitoring the output voltage and output current.)
If this material meets my specifications, I want to confirm the following questions.
A. Can the output voltage & frequency be set by analogy? Or must it be set by digital?
B. How to read the output and edit the register? ( TPS546B24A > PMBus > Dongle > PC ? , If this is the path, what kind of dongle do I need? )
C. The accuracy of the output can be adjusted? Each scale is 0.1V?
