Hi TI,
What's the recommended feedback resistors when Vout=0.8V? Shoud I use 0ohm pull-up resistor? What's the recommended pull-down resistance? Thank you.
Hi TI,
The feedback voltage is 0.8V. So you can tie the FB pin to Vout to set the output to 0.8V.
You can use a zero ohm resistor if you would like or just a trace on the board.
- Stephen
