Part Number: BQ25070
Other Parts Discussed in Thread: BQ25071, BQ24210
The datasheet for the BQ25070 briefly mentions Vin-DPM which I believe would make it suitable as a solar charger for LiFePO4 single cells.
- Can you confirm the suitability of the BQ25070 for a solar charging application?
- There is no mention of the Vin-DPM voltage, can you please confirm what it is pre-set to?
- The pulse control Table 1 doesn't specify how to control Vin-DPM and whether it is enabled by defualt. Can you please confirm?
- Does the BQ25071 also have the Vin-DPM feature (it is not mentioned in the datasheet but [this](https://e2e.ti.com/support/power-management/f/196/p/743001/2744499#2744499?jktype=e2e) states the only difference is the CTRL/EN pin7)?
Thank you for your time.
