Other Parts Discussed in Thread: BQ34Z100, BQ24610, BQ25713, EV2400, BQ25713EVM-017, BQ25713B
We are conducting academic research related to electric drivetrains and want to be able to charge Li-ion battery packs using a small DC generator of sorts. The DC output from it would need to be fed into a charger first, to charge the Li-ions correctly.
- We are considering buying one of your charger EVMs (such as BQ24610EVM) considering multi-cell capability and high ranges of voltage input/output seem appropriate.
- However I am unable to find (apart from the std. user guide) any reference on how to make these connections to actually charge the batteries for evaluation and powering our Load parallely.
- The user guide says says something about changing some 'R25 or R28' values. Does this mean physically adding/removing resistors on the PCB or is it a jumper setting? We are looking to eventually evaluate different packs (1S, 2S, 3S and 4S); so it is a bit unclear if the same module (which is a multi-cell charger) is able to help us do the evaluation of all our Li-ion packs.
- We are using the BQ34z100 EVM as our fuel-gauge to log data such as SOC, voltage etc. And the charger is supposed to go across the (BAT+,PACK-).
Are there any other appropriate suggestions of a product we could purchase instead?
Shrey KALRA
(Research Engineer)
NTU - Singapore
