Other Parts Discussed in Thread: UCC28700
Dear supporters,
I need some explanation on ACon and ACoff parameters for UCC2863x controller.
They should indicate minimum and maximum AC (or DC if multiplied by sqrt(2)) input voltage to start or stop IC operation, but i don't understand how to use the provided parameters.
The input voltage (voltage on bulk capacitor) is sensed by auxiliary winding of power transformer during Ton of power switch shifting the sensed voltage with the suggested resistor/diode circuit, but in section 8.4.1 of datasheet, the first two parameters in table 6 refer to line voltage. Is this data provided by assuming fixed transformer turns ratio? What is the equivalent sensed threshold voltage?
