I use the Part to generate 1.8V from 3.3V.
The Voltage on the TPS82085 Output is wrong, around 0.45V. I think this comes from the load ICs that have several power supplies.
I think, that the part is not correctly soldered.
On the filter on top of the part I measure around 2.5V. (So the voltage is higher than the Vout nominal)
Althougth tte output Voltage is wrong, the power good pin is active.
Is this behaviour correct?
