TPS54231: Output ripple during start up
Part Number: TPS54231
the circuit is as below: we are converting 12V to 5V, we cut all the load on 5V power rail so it's 0 load.
When we float EN pin, we got the waveform below:
yellow-12V input, blue-EN pin, green- 5V output.
by zoom in we get the waveform:
by solder R406=200k, R430=40k, we can get normal start up waveform as below:
yellow-12V input, blue- EN pin, green- 5V output.
Why would floating EN pin cause the ripple of Vout, it looks like it stops and then restart, but floating EN pin should be default enable this device.
  • Hi Howard,
    Could you help capture the SS voltage as well?  One possible reason is EN is sensitive to noise when floating.
  • Hi Howard,
    The EN pin has an internal pullup current-source that enable the pin by default. I switching on the EN pin does not look right to me. can you please why EN is noisy like that.
    The other thing I can notice from the plot is the VOUT is overshooting, then stops regulating, then VOUT drops, and the process repeats itself 3 times before it regulates to normal, this may be an indication of Inductor sizing or noise into FB pin. Can you please zoom in time to see the 3 spikes and include the SW, EN, SS, VOUT to see if the switching stops after the overshoot happens.
    Thanks!
    Tahar
    thanks
    Tahar
