Other Parts Discussed in Thread: LP2951
When pulling the LP2951 shutdown pin low to disable the regulator, we noticed that the error (open collector output) pin is being pulled low. Does the error detection comparator circuit stay powered and active when the shutdown pin is pulled low (regulator disabled)? This is not explicity described anywhere in the data sheet but is very important for low power applications since the active low output with a pullup to an external supply will cause some quiescent current draw.
