TPS22915: Recommended input voltage
Part Number: TPS22915
Hi team,
Our customer want to know the characteristic or the problem when input voltage is 0.9V(recommended input voltage is 1.05V to 5.5V).
The customer want to know the mechanism of why the problem occur too.
Please explain why the problem is occur.
best regards
teritama
  • Hi Teritama,
    The minimum voltage to power this device is 1.05V. This means that at lower voltae, the device will not be able to set the internal thresholds and may not be able to turn on and perform as expected.
    Another major concern is that all datasheet specifications and performance are defined under recommended operating conditions.
    Thank you for choosing TI Load Switches.
