I'm planning to use the BQ51013B with an external adapter and want to know if I can use the CHG/ output to determine whether the source of power on OUT is wireless or wired (different current capacities). The datasheet is a bit ambiguous:
CHG : Open-drain output – active when OUT is enabled. Float or tie to PGND if unused.
Will CHG/ pull low only in the presence of a Qi transmitter or will it also pull low when the Adapter PMOS is on and driving OUT?
Steve C
