Other Parts Discussed in Thread: LMR62014
We used a webbench design to setup the LM43601 for 5V input and -15V output at 0.1A. We are having trouble getting the -15V output to function.
If you manually short circuit from -15Vout to GND for a moment, the output will often start working.
I saw a post suggesting a 0.47uF soft start cap from pin 11 to -Vout. This was tried, but did not change anything.
We found that the datasheet (and some other forum posts) say to short the SYNC pin to GND. We have tried that pin shorted to -Vout, but it did not change anything.
Attached are the schematic and board layout.
Thanks for any help you can provide
