Hello everyone,
I am using the TPS73801-SEP LDO in my design, to generate 20 positive voltages and i should generate the 21st one which is a negative one with the same LDO, one year ago i did see this topic in this forum, i tried to find it but in vain. Can you please tell me how to it properly?
The second question, is about the EN pin, actually I am using an FPGA to drive it, I notice that sometimes the LDO is activated when the FPGA is in a high impedance, should i understand that there is no pull down in the IC? should i put a pull down?
Hassan OU-AYACHE
