Does the BQ25887 have the capability to detect when a battery is present or not? Presently I am using the voltage; however, if the IC is charging and a battery is removed, then the charging voltage is present on the A/D and we measure that which is detected as a battery. Does the BQ25887 have a better way to do this. I checked the datasheet and could not find anything. Thank you.
