Hi support team,
I design with a 10-layer board.
It is designed with reference to the evaluation board and data sheet.
What should I do with the surplus layer?
Should I use solid GND?
Dice-K
Hi support team,
Dice-K
If you have 4 extra layers, I would recommend filling any unused space with ground pours. With 4 extra layers, you could also put more layers between the digital signals and the switching regulators but they work fine as is so that's low priority.
