Other Parts Discussed in Thread: TPS62868, TPS62869
Hi Team,
Need your help to share or comment for what the load regulation tolerance would be when output is 1V?
Albert Lee.
Hello Albert,
I see you opened different thread with the same question, the Load regulation is defined at one condition in most of our DCDC regulator datasheet.
What exactly is your customer concern here?
Maybe we can address it differently than looking at 1.0V load regulation parameter.
Let me know!
Dorian
Hi Dorian,
In both datasheets, it only have 1.8Vout load regulation curve. But our customer applications is for 1V Vcore output and that's why need your help to share or provide the load regulation curve with 1V output application.
Albert Lee.
Hello Albert,
The 1.0V load regulation was not tested during validation, but as you are evaluating several devices I recommend you look at their respective performances using WEBENCH available on each product webpage.
I would also suggest you evaluate the new TPS62869/TPS62868 (6A and 4A), where you can see typical load regulation behavior at 1.2V and 0.9V to give you a good estimation on 1.0V.
Let me know!
Thank you,
Dorian
