Other Parts Discussed in Thread: TPS544C20
We are planning to use TPS544B20 regulator for core supply in our system. The core supply will be enabled after the IO supplies are turned ON as per sequencing requirements. I need to turn ON the TPS544B20 after IO supply comes up. I want to use 3.3V supply for enabling TPS544B20 core regulator. As read in other posts, by default, the regulator will be enabled once CNTL pin sees high, please re-confirm.
We have only I2C bus on board and want to use it to vary the output voltage of TPS544B20 using I2C. Since the device supports PMBUS and as we know PMBUS is superset of I2C, is there any thing to be taken care in software to use I2C to write/read registers of TPS544B20? Can I use system 3.3V as pull-up for I2C?
Naveen
