Part Number: BQ24085
Hello, I want to use /PG signal as a Vin presence detección signal, but we I remove Vin /PG signal doesn't change.
Could you tell me if I can use /PG signal for this purpose or it only Works as an overvoltage detection?
OK, The problem is that when I have a battery connected, and I remove Vin, /PG doesn't change to high impedance.
HI Vicente,
Can you provide a schematic? Can you also provide the voltage and current you have at the input?
Hi Vicente,
Can you provide a scope shot of the input voltage and current with /PG when this happens? Can you also provide a scope shot for the output voltage and waveform with /PG when this happens?
Hi Vicente,
With the /PG pin, assuming you are using a microcontroller, please connect a pull-up resistor between the processor's power rail and the PG terminal.
