TPS612592: if TPS612592A (5.2V version) is available and is pin-to-pin compatible with TPS61253A
Part Number: TPS612592
Other Parts Discussed in Thread: TPS61253A,
hi.
Pls check TPS612592A (5.2V version) is available to order and is pin-to-pin compatible with TPS61253A
  • Hi Jazz,
    Right now only TPS612592 is available on ti.com. The A version is not RTMed yet.
    TPS612592 has same package size with TPS61253A but not all pins and functions are the same. For example, TPS612592 C3 pin is BP pin. TPS61253A C3 pin is MODE pin. You can read the datasheet to find the detail difference.
