Other Parts Discussed in Thread: TPS1H000-Q1, TPS1H200A-Q1
Hi team,
for some design requirements, I need to use a single channel FET with currente sense output and external current limited set to 300mA (<500mA).
I have seen that no TEXAS device has both, so I focused on using the TPS27S100B.
For this device, however, the use with external limitation current > = 500mA is specified in the datasheet.
Can you tell me if I can use it without problems at a current of 300mA and I would also like to know what limit tolerances I should expect?
If it is not compatible with my specifications, could you possibly indicate a replacement that allows me to do what is requested?
Many Thanks.
Ivan
