Hi Team,
Could you please help to check the following SCH?
Hello
I don't see anything outstanding in the design.
Here are my comments:
1. It appears that the RT resistor is not used; open = 500kHz
2. Your output capacitance is a little small, but should be OK. You may want to leave space on the PCB for another output
cap to improve transient response.
3. You may want to leave room on the PCB layout for a feed-forward capacitor across the upper feed-back resistor; if needed.
4. Be sure that the inductor is rated for at least the typical value of the high-side current limit.
5. Be sure to follow the data sheet PCB layout suggestions.
Hello
I will close this post due to inactivity.
If you need more help, you can re-open.
