Other Parts Discussed in Thread: TPS65631W
Hi team,
Customer is using RT4731, we are promoting our solution, is TPS65632 a suitable part for this application? Could you suggest a proper part for this application?
Thanks and Best Regards,
Will
Hi Will,
We don't have an exact cross but TPS65632 is the closest suitable device for crossing this. The negative output voltage range and AVDD voltage are not quite the same between the two devices but you can check with customer to see if this one can work in their application.
TPS65632 is a three output rail device and we also have a two output rail device TPS65631W for smart watch applications.
Kind Regards,
Liaqat
