Hi expert,
Can we adjust dv/dt capacitor to achieve 100mV/ms slew rate?
Jimmy
Hi Jimmy,
Can you please provide the following details,
For some reason the image shared by you has not uploaded properly. Can you try uploading it using the attachment symbol in .PNG format.
Hi Praveen,
Input voltage 5V, Load 15mA, no other load, slew rate 100mV/ms is application required, 100uF output cap.
Jimmy
Hi Jimmy,
TPS25980 can startup into 100uF output cap very quickly. Can you help us understand why you need so slow startup ?
Hi Praveen,
100mV/ms is required by customer. If TPS25980 can not support it, do we have other recommendation?
Jimmy
Hi Jimmy,
There is no limitation in using Higher dvdt cap on TPS25980 to achieve slow ramp rate like 100mV/ms.
You can calculate the cap required on dvdt to achieve 100 mV/ms using the design calculator and test it on EVM.
Hi Praveen,
Thanks for your feedback. Will give feedback to you after I finish this test.
Jimmy
Thanks!
