Hi,All.
The TPS60240 has a buck-boost, but is the operation during step-down the same as that of a linear regulator?
Hi,All.
Hello user648367,
You mean when VIN is above VOUT, correct? I need to check with the designer.
In the case when VIN is smaller than VOUT, the input current is bigger than the output current.
Hello user6483867,
I will get back to you with an answer to the input current with input voltage above output voltage in the next days, latest beginning of next week.
