Hi team,
My customer is considering to use TPS62135. Could you support the questions below?
1. Regarding VSEL-pin.
The Figure 83. Typical Application using VSEL in the d/s shows how to use the VSEL-pin. R2 and R3 are in parallel. Customer would like to connect R2 and R3 in series. Please refer to the following pptx file. Is that acceptable? Could you let me know if there are any concern for the usage?
/cfs-file/__key/communityserver-discussions-components-files/196/TPS62135-VSEL-function.pptx
2. Regarding VSEL-pin, EN-pin, and MODE-pin.
Are there internal pull down resistors in these pins?
Yamaguchi
