Other Parts Discussed in Thread: BQ2970
Hi Sir,
Would you pls advise if Vbat between 1.7V and 0.75 will doesn’t be charged?
Thanks, Ian.
Hi Sir,
Thanks, Ian.
Hi Ian,
The BQ2970 has a 0-V battery charge feature, which means that the device will allow charging when the battery voltage is in between 0.75V and 1.7V.
Hi Shawn,
What means as d/s table shows 1.7V is min. ,0.75V is Max.?
Thanks. Ian.
Hi Ian,
This value is to identify the range for this feature. The function will start when the battery depletes to 1.7V, and stops when the battery reaches the value of 0.75V.
Hi Shawn,
Is it means charging will be forbidden when bat. voltage lies in 0.75~1.7V ?
Thanks, Ian.
Hi Ian,
If the battery cell is greater than 0.75V, and the charger voltage is greater than 1.7V, the device will charge. Once the battery cell drops below 0.75V, or the charger below 1.7V, then charging will stop.
