Is it save to apply a voltage to the output pins (SW, VOUT/BIAS/FB) of the LMR36506-Q1 and also apply a clock signal to the SYNC pin, while there is no voltage applied to VIN?
Current flow from the output (SW) to the input (VIN) of the device can not be tolerated in this application. (Current flow into SYNC is neither.)
Thank you very much
