Other Parts Discussed in Thread: TPS61022
Hi team,
I have a couple questions regarding this chip. It is driving a TPS61022. I have a block diagram and schematic to share as well, let me know if you need those and I will share internally.
1. If this chip is turned on and not programmed by the host MCU, what's the default supply current on the Sys output? Assuming you have a 4.2V input coming in from the fuel gauge with the battery.
2. What is a recommended ILIM resistor value?
3. What could be causing the drop? The output is going to both a 3.3V LDO and the 4.2V output TPS61022, perhaps it is not able to supply enough current? The dropout occurs as soon as the TPS61022 is enabled.
