Hello Guys,
Good day.
Our customer wanted to know what resistor to use for R1 (stat PU) listed in the datasheet. It doesn't indicate what resistance pulls it low. Presumably the PU needs to be a higher resistance. So it pulls up if stat is High-Z, and pulls low if stat is low.
In addition, what would cause Input 2 to not be active, even with D0 and D1 set low? On his design Input 1 works when D0 is high, as expected. However only part of Input 2's voltage is being passed through.
Thanks!
Art
