Other Parts Discussed in Thread: TPS2660
I'd like to use the TPS26622 load switch/hot-swap controller in my design. I was wondering if the voltage on the "ILIM" pin is proportional to load current, so that it could be used as a current monitor (by connecting it to an ADC). Would this work? (This usage of ILIM is not described in the datasheet.) And if it is possible, what is the scale factor from load current - to - voltage @ ILIM ?
Thank you,
Mohan
