BQ27441EVM-G1A: BQ27441EVM-G1A
Part Number: BQ27441EVM-G1A
I utilize GPOUT to trigger a refresh on a set of display icons showing the SOC and whether the device is connected to power for charging...
When I remove charging power (and operating solely on battery) GPOUT pulses as it should, however, when I reconnect charging power, GPOUT does NOT pulse, and I require it to do so... is there a way to configure the device (I’m currently using the default setup) such that a reconnection of charging power pulses GPOUT? And if so, how would this specifically be accomplished.
Thank you,
Chuck
