BQ24045: BQ24045 Charging problem
Part Number: BQ24045
Hi TI Team,
Due to structural problems, the battery end is about 22cm away from the BQ24045 Out Pin. When the battery voltage is 3.8V, plug in the USB to charge, you will find that there is charging current, but the charging 8 PIN shows a high impedance state. After 7 minutes, the charging current is normal and the 6PIN output is normally low. Is the abnormal waveform below? Is there a solution?
