Part Number: TPS25925
According to datasheet, current limit is 2A~5A.
Base on equation, if I use Rlim=24.9kohm get 1.45A current limit.
My question is can I set current limit 1.45A of the e-fuse?
Hi Jim,
The accuracy of current limit varies with process, voltage and temperature. The value of current limit from 2A-5A will have a tolerance of 15% and are quite accurate and recommended .
You can choose RILIM 24.9kohm to get current limit of 1.45A but it will have a tolerance of around 20-30% which may not be acceptable for your system.
Please refer this graph for more understanding:
Kunal Goel
