Hi Sir,
Pls advise charger voltage means: charger IC will give small current for charge when battery voltage>0.75V, and make sure if battery voltage rise up to 1.7V?
Thanks, Ian.
Hi Sir,
Thanks, Ian.
Hi Ian,
The BQ2970 does not have a precharge path to limit current during low voltage. It does allow zero volt (0-V) charging down to its inhibit voltage. The charger must limit the current if it recognizes the low voltage when the charge FET comes on, the BQ2970 does not limit current.
