Part Number: TPS54201
Hello team,
My customer has a question about the failure mode of the LED driver TPS54201.
Is it possible to consider a failure mode in which the load (LED) continues to flow at the designed upper limit current value when this component fails?
Since the customer uses a high-power LED, it will generate heat if it continues to flow at the maximum current, so they want to confirm it in terms of product safety.
Ryotaro Fukui
