TPS22919: Enable voltage
Part Number: TPS22919
Hi.
The ON Pin Low Voltage Range is from 0 to 0.35 V in datasheet. Question is, if the maximum low voltage of the device that will enable/disable the load switch is 0.4 V, the load switch would be disabled or there is a risk that it will not be disable?
Thanks.
