Dear,
Do we have below latch up information for TPS22913CYZVR? Thanks.
Hi Jiayu,
We do not spec this parameter for TPS22913. All ESD ratings for this device are in Section 8.2 of the datasheet and they only include HBM and CDM.
Hi Shreyas Dmello,
So you mean we didn't have such info for TPS22913, right? Would you please double confirm with designed internally. then I will reply to customer. Thanks
Hi Jiayu,
We do not typically define or spec this parameter on the datasheet. You can view the qualification summaries for this device on ti.com.
https://www.ti.com/qualificationsummary/qualsumm/home?actionId=2800
As you can see for TPS22913, the device passes the latch up test per JESD78 classification.
