Iam Planning to use LM5001 in isolated flyback controller (DCM) topology. iam planning to charge a battery pack of 74V with this converter. i need only the current regulation to happen and i don't need voltage regulation ( CV at output of flyback ). Is it fine if i connect both COMP and FB pins to ground to achieve this desired operation?. Or may i know if its not possible by above method, what could be the best solution. What could be the best config of COMP and FB pin's to charge a 74V battery from it
