Other Parts Discussed in Thread: TPS3899
Hello team,
My customer has a question about TPS38x-Q1: How reset output behaves and how its related with monitoring voltage.
Please see the graph in the attached file. Questions are 3 below:
- Is it correct that the monitoring voltage needs to be below the threshold for >10% or >5% time period of set delay time in order to operate reset release?
- Is there no particular time period stated for exceeding the monitoring voltage threshold? Is it simply canceled if it exceeds the Delay setting time, and is not canceled if it is not exceeded?
- If the voltage above and below the monitoring voltage threshold is repeated, is the understanding in following cases true?(From p.2 of slides)
I am not familiar with this field and the question text may be strange, but if you have any comments about it, please contact me.
Ryotaro FukuiTPS38x-Q1_ResetOutput&VoltageMonitorThreshold.pptx
