Hi team,
Could you tell me your comment about my understandings and questions?
- Vout positive abs max voltage due to inductive load:
The Vout positive voltage could be VBB + FET body diode voltage drop. So the Vout abs max is depending on VBB abs max; 36V - Vout negative abs max voltage due to inductive load:
The Vout negative voltage could be depending on "VDS clamp voltage" @ inductive load turning off. - Or does it have Vout abs max negative voltage or its limitation?
Ochi
