Other Parts Discussed in Thread: UCC5350, CSD19532Q5B,
Hello TI,
I am trying to simulate an isolated high side floating gate driver using LM5161 , TPS7A2601, UCC5350 and CSD19532Q5B Mosfet combination. I am trying to confirm this design works.
However simulation always gave me convergence problem. I tried many thing but could not get over it.
Any help appriciated.
Dsn and output file attached.
I am using Pspice for TI 17-04-2020 S004 Win SPB 64 bit.
PArt of error:
WARNING(ORPSIM-15452): Pulse Period < (Rise Time + Fall Time + Pulse Width) for V_V10.
Reducing minimum delta to make the circuit converge.
ERROR(ORPSIM-15138): Convergence problem in Transient Analysis at Time = 210.0E-06.
Time step = 270.6E-21, minimum allowable step size = 1.000E-18
These supply currents failed to converge:
I(X_U2.E_E36) = 1.077mA \ 697.04uA
I(X_U3.E_U1_E12) = 1.249mA \ -2.785mA
I(V_V8) = -429.28pA \ -422.01pA
I(V_V10) = -1.883A \ 203.13mA
I(X_U1.V_U4_V86) = -8.821pA \ -33.01pA
I(X_X2.xcgd.v1) = 0A \ 7.276pA
I(X_X2.xcgs.v1) = 0A \ 7.276pA
I(X_X2.xcds.v1) = 0A \ 7.276pA
All the bests,
Savasisolated_gate_Driver_UCC5350_pspiceTi.pdf
**** 02/20/21 01:26:12 ******* PSpice 17.4.0 (Nov 2018) ******* ID# 0 ******** ** Profile: "SCHEMATIC1-gate_driver_isolated" [ d:\_ti_projs\ucc5350_floating_gatedriver\isolated_gate_driver_ucc5350-pspicefiles\s **** CIRCUIT DESCRIPTION ****************************************************************************** ** Creating circuit file "gate_driver_isolated.cir" ** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS *Libraries: * Profile Libraries : * Local Libraries : * From [PSPICE NETLIST] section of D:\_TI_projs\cdssetup\OrCAD_PSpiceTIPSpice_Install\17.4.0\PSpice.ini file: .lib "nom_pspti.lib" .lib "nom.lib" *Analysis directives: .TRAN 0 0.036 0.0 0.001 SKIPBP .OPTIONS ADVCONV .PROBE64 I(R_R4) .PROBE64 I(R_R2) .INC "..\SCHEMATIC1.net" **** INCLUDING SCHEMATIC1.net **** * source ISOLATED_GATE_DRIVER_UCC5350 X_U1 N14903 N14907 N18996 N17075 N16148 N17933 N16148 N14868 N15477 + N15477 0 0 0 N19336 N22285 LM5161_TRANS PARAMS: SS=0 X_TX1 N15477 N15530 GND_SIGNAL N18256 SCHEMATIC1_TX1 C_C1 0 N14868 10u TC=0,0 C_C2 0 N14868 470n TC=0,0 R_R1 N14868 N14903 402k TC=0,0 R_R2 N14907 N14868 100k TC=0,0 R_R3 0 N14907 5k TC=0,0 C_C3 0 N17075 22n TC=0,0 C_C4 N15477 N17933 10n TC=0,0 R_R4 N15477 N15484 100k TC=0,0 C_C5 N15484 N18996 100n TC=0,0 C_C6 N15484 N15530 1n TC=0,0 D_D1 N15530 N16148 Dbreak C_C8 N15530 0 10u TC=0,0 C_C9 N15530 0 1u TC=0,0 R_R6 N18996 N15530 13.7k TC=0,0 R_R7 0 N18996 2k TC=0,0 C_C7 N16148 0 100n TC=0,0 C_C10 GND_SIGNAL N17625 10u TC=0,0 D_D2 N18256 N17625 Dbreak R_R13 0 N19336 20000k TC=0,0 R_R14 N22285 0 20000k TC=0,0 X_U2 N24418 0 N25027 0 N24422 N37449 N24335 GND_SIGNAL UCC5350MCD_TRANS R_R17 N24422 N24418 1 TC=0,0 V_V3 N25027 0 +PULSE 0 3 30m 40n 80n 1000m 1100m C_C11 GND_SIGNAL N24335 1u TC=0,0 C_C14 GND_SIGNAL N17625 1u TC=0,0 V_V5 N37449 0 3Vdc C_C12 N37449 0 1u TC=0,0 C_C13 N37449 0 470n TC=0,0 M_M2 N15530 N39962 N399540 N399540 MbreakN R_R23 0 N399540 15 TC=0,0 V_V7 N39962 0 +PULSE 0 25 30.5m 10n 10n 100m 100m X_U3 N17625 N42909 GND_SIGNAL N43945 N17625 N24335 TPS7A2601_TRANS C_C15 N24335 GND_SIGNAL 10u TC=0,0 C_C16 N24335 GND_SIGNAL 1u TC=0,0 R_R24 N42909 N24335 1100k TC=0,0 R_R25 GND_SIGNAL N42909 100k TC=0,0 R_R26 N24335 N43945 1100k TC=0,0 X_X2 N47591 N24418 GND_SIGNAL CSD19532Q5B R_R21 GND_SIGNAL N47715 10 TC=0,0 V_V9 N47715 0 42 R_R27 N47591 N47603 0.001 TC=0,0 V_V8 N47603 0 60 V_V10 N14868 0 +PULSE 0 40 0 1000u 1000u 100m 100m .subckt SCHEMATIC1_TX1 1 2 3 4 K_TX1 L1_TX1 L2_TX1 1 L1_TX1 1 2 100uH L2_TX1 3 4 100uH .ends SCHEMATIC1_TX1 **** RESUMING gate_driver_isolated.cir **** .END INFO(ORPSIM-15453): Model X_X2.NMOS: Using BSIM VERSION 3.2 **** 02/20/21 01:26:12 ******* PSpice 17.4.0 (Nov 2018) ******* ID# 0 ******** ** Profile: "SCHEMATIC1-gate_driver_isolated" [ d:\_ti_projs\ucc5350_floating_gatedriver\isolated_gate_driver_ucc5350-pspicefiles\s **** Diode MODEL PARAMETERS ****************************************************************************** X_X2.DBD X_U2.X_U3.dd X_U2.X_U55.dd X_U2.X_U10.dd T_Measured 25 T_Current 27 IS 5.000000E-12 10.000000E-15 10.000000E-15 10.000000E-15 N 1.045 1.000000E-03 1.000000E-03 2.3 BV 101 RS 750.000000E-06 TT 2.000000E-09 CJO 1.000000E-18 VJ .5 M .625 XTI 3.3 TRS1 4.000000E-03 X_U2.X_U57.dd X_U2.X_U11.dd X_U2.X_U5.dd X_U2.X_U9.dd IS 10.000000E-15 10.000000E-15 10.000000E-15 10.000000E-15 N 1.000000E-03 1.000000E-03 2.3 X_U2.X_U8.dd X_U2.X_U30.d_d1 X_U2.X_U4.dd X_U2.X_U60.dd IS 10.000000E-15 1.000000E-15 10.000000E-15 10.000000E-15 N .1 1.6 1.000000E-03 RS .05 TT 10.000000E-12 X_U2.X_U56.dd X_U3.X_U1_U20.dd1 IS 10.000000E-15 1.000000E-15 N 1.000000E-03 .1 RS .05 TT 10.000000E-12 X_U3.X_U1_U11.dd1 IS 1.000000E-15 N .1 RS .05 TT 10.000000E-12 **** 02/20/21 01:26:12 ******* PSpice 17.4.0 (Nov 2018) ******* ID# 0 ******** ** Profile: "SCHEMATIC1-gate_driver_isolated" [ d:\_ti_projs\ucc5350_floating_gatedriver\isolated_gate_driver_ucc5350-pspicefiles\s **** MOSFET MODEL PARAMETERS ****************************************************************************** MbreakN X_X2.NMOS X_U2.X_M14._mod X_U2.X_M16._mod NMOS NMOS NMOS PMOS T_Measured 25 T_Current 27 LEVEL 1 7 1 1 L 100.000000E-06 100.000000E-06 10.000000E-09 10.000000E-09 W 100.000000E-06 100.000000E-06 1.8 .107 VTO 0 .7 .2 -.2 KP 20.000000E-06 51.797160E-06 8.080000E-09 2.000000E-09 GAMMA 0 0 0 0 PHI .6 .6 .6 LAMBDA 0 0 0 0 IS 10.000000E-15 1.000000E-15 10.000000E-15 10.000000E-15 JS 0 0 0 0 N 2.5 2.5 PB .8 1 .8 .8 PBSW .8 1 .8 .8 CJ 0 1.000000E-18 0 0 CJSW 0 1.000000E-18 0 0 CGSO 0 1.000000E-18 0 0 CGDO 0 1.000000E-18 0 0 CGBO 0 1.000000E-18 0 0 NSUB 10.000000E+15 TOX 0 40.000000E-09 0 0 XJ 0 300.000000E-09 0 0 UCRIT 10.000000E+03 10.000000E+03 10.000000E+03 10.000000E+03 DELTA .022 DIOMOD 1 2 1 1 VFB 0 -1 0 0 LETA 0 0 0 0 WETA 0 0 0 0 U0 0 650 0 0 TEMP 0 0 0 VDD 5 5 5 XPART 0 0 0 0 UA 1.400000E-09 UB 5.000000E-18 UC -46.500000E-12 VSAT 80.000000E+03 RDSW 0 VOFF -.37 NFACTOR 2 PCLM .25 PDIBL1 .02 PDIBL2 4.000000E-03 DROUT .9 PSCBE1 300.000000E+06 PSCBE2 1.000000E-06 A0 1 A1 0 A2 1 NPEAK 148.500000E+15 VBM -5 LDD 0 LITL 189.736700E-09 KT1 -1.1 UA1 25.000000E-12 UB1 -800.000000E-21 UC1 -56.000000E-12 PVAG .1 ETA0 5.000000E-03 KT1L 1.000000E-15 DSUB 1.4 MOBMOD 1 PRWG 0 LINT 55.000000E-09 DLC 55.000000E-09 DWC 0 CF 0 NOIA 100.000000E+18 NOIB 50.000000E+03 NOIC -1.400000E-12 VTM .025692 VERSION 3.2 PBSWG 1 MJSWG .33 CJSWG 1.000000E-18 JTSCD 0 TOXM 40.000000E-09 LLC 0 LWC 0 LWLC 0 WLC 0 WWC 0 WWLC 0 X_U2.X_M13._mod X_U2.X_M15._mod NMOS NMOS LEVEL 1 1 L 10.000000E-09 10.000000E-09 W .5 .5 VTO .2 .2 KP 9.600000E-09 9.600000E-09 GAMMA 0 0 PHI .6 .6 LAMBDA 0 0 IS 10.000000E-15 10.000000E-15 JS 0 0 N 2.5 2.5 PB .8 .8 PBSW .8 .8 CJ 0 0 CJSW 0 0 CGSO 0 0 CGDO 0 0 CGBO 0 0 TOX 0 0 XJ 0 0 UCRIT 10.000000E+03 10.000000E+03 DIOMOD 1 1 VFB 0 0 LETA 0 0 WETA 0 0 U0 0 0 TEMP 0 0 VDD 5 5 XPART 0 0 **** 02/20/21 01:26:12 ******* PSpice 17.4.0 (Nov 2018) ******* ID# 0 ******** ** Profile: "SCHEMATIC1-gate_driver_isolated" [ d:\_ti_projs\ucc5350_floating_gatedriver\isolated_gate_driver_ucc5350-pspicefiles\s **** Resistor MODEL PARAMETERS ****************************************************************************** X_X2.RTEMP R 1 TC1 8.000000E-03 TC2 25.000000E-06 **** 02/20/21 01:26:12 ******* PSpice 17.4.0 (Nov 2018) ******* ID# 0 ******** ** Profile: "SCHEMATIC1-gate_driver_isolated" [ d:\_ti_projs\ucc5350_floating_gatedriver\isolated_gate_driver_ucc5350-pspicefiles\s **** Voltage Controlled Switch MODEL PARAMETERS ****************************************************************************** X_U2.X_S1._S1 X_U2.X_S2._S2 X_U3.X_S2._S2 X_U3.X_S4._S4 RON 1 1 .1 1.000000E-03 ROFF 100.000000E+06 100.000000E+06 100.000000E+03 1.000000E+09 VON .6 .6 .8 0 VOFF .4 .4 0 1 X_U3.X_S3._S3 X_U3.X_S1._S1 RON 1.000000E-03 100.000000E-06 ROFF 1.000000E+09 1.000000E+09 VON 1 1 VOFF .2 .2 WARNING(ORPSIM-15452): Pulse Period < (Rise Time + Fall Time + Pulse Width) for V_V10. WARNING(ORPSIM-15452): Pulse Period < (Rise Time + Fall Time + Pulse Width) for V_V10. Reducing minimum delta to make the circuit converge. Reducing minimum delta to make the circuit converge. Reducing minimum delta to make the circuit converge. Reducing minimum delta to make the circuit converge. Reducing minimum delta to make the circuit converge. ERROR(ORPSIM-15138): Convergence problem in Transient Analysis at Time = 210.0E-06. Time step = 270.6E-21, minimum allowable step size = 1.000E-18 These supply currents failed to converge: I(X_U2.E_E36) = 1.077mA \ 697.04uA I(X_U3.E_U1_E12) = 1.249mA \ -2.785mA I(V_V8) = -429.28pA \ -422.01pA I(V_V10) = -1.883A \ 203.13mA I(X_U1.V_U4_V86) = -8.821pA \ -33.01pA I(X_X2.xcgd.v1) = 0A \ 7.276pA I(X_X2.xcgs.v1) = 0A \ 7.276pA I(X_X2.xcds.v1) = 0A \ 7.276pA Last node voltages tried were: NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE (N14868) 8.4001 (N14903) 2.1698 (N14907) .4000 (N15477) 1.593E-06 (N15484) 253.7E-09 (N15530) 1.584E-06 (N16148) 1.211E-09 (N17075) 2.836E-15 (N17625) .8553 (N17933) 1.593E-06 (N18256) .8554 (N18996) 226.8E-09 (N19336) 0.0000 (N22285) 0.0000 (N24335) .0041 (N24418) .8547 (N24422) .8545 (N25027) 0.0000 (N37449) 3.0000 (N39962) 0.0000 (N42909) .7838 (N43945) .2000 (N47591) 60.0000 (N47603) 60.0000 (N47715) 42.0000 (X_X2.4) 60.0000 (X_X2.5) .8548 (X_X2.6) .8554 (X_X2.7) 60.0000 (X_X2.8) .8554 (X_X2.9) .8554 (N399540) 32.94E-18 (X_U1.EN) 0.0000 (X_U1.QB) 1.0000 (X_U1.QD) 0.0000 (X_X2.10) 60.0000 (X_X2.11) .8547 (X_X2.12) .8554 (X_U1.CON) 3.100E-09 (X_U1.QBD) 1.0000 (X_U2.ASD) 1.0000 (X_U3.PG2) 0.0000 (X_U3.VXX) .8556 (X_U3.VYY) .8556 (X_U3.VZZ) .8556 (X_U1.ILIM) 0.0000 (X_U1.LS_G) 1.0000 (X_U1.SET3) 0.0000 (X_U1.U2_Q) 0.0000 (X_U1.VREF) 2.836E-15 (X_U2.DRVA) 0.0000 (X_U3.LOAD) 851.5E-12 (X_U3.VINT) .8554 (GND_SIGNAL) .8554 (X_U1.CLAMP) 2.0000 (X_U2.UVLO1) 1.0000 (X_U2.UVLO2) 0.0000 (X_U3.DISCH) 0.0000 (X_U3.EN_OK) 0.0000 (X_U3.ROUT1) .0060 (X_U3.VOUT1) -.8512 (X_U3.V_FBK) -.0715 (X_U1.U1_PSM) 0.0000 (X_U1.U2_SET) 0.0000 (X_U2.GATE_N) .8545 (X_U2.GATE_P) .0041 (X_U2.INN_OK) 1.0000 (X_U2.INP_OK) 0.0000 (X_U2.X_U6.1) 1.0000 (X_U2.X_U7.1) 0.0000 (X_U3.EN_INT)-47.67E-06 (X_U3.EN_OK1) 0.0000 (X_U3.X_X1.6) .8556 (X_X2.xcds.5) 59.1450 (X_X2.xcds.6) 545.4E-12 (X_X2.xcds.7) 0.0000 (X_X2.xcds.8) 0.0000 (X_X2.xcgd.5) 59.1450 (X_X2.xcgd.6) 14.70E-12 (X_X2.xcgd.7) 0.0000 (X_X2.xcgd.8) 0.0000 (X_X2.xcgs.5) 59.1450 (X_X2.xcgs.6) 1.550E-09 (X_X2.xcgs.7) 0.0000 (X_X2.xcgs.8) 0.0000 (X_U1.U2_Q_ND) 0.0000 (X_U1.U3_COFF) 20.01E-06 (X_U1.U3_TOFF) 0.0000 (X_U1.U4_SHDN) .4955 (X_U2.INN_INT) 0.0000 (X_U2.INP_INT) 0.0000 (X_U2.UVLO_OK) 0.0000 (X_U3.DISCH_B) 1.0000 (X_U3.N430125) 0.0000 (X_U3.N430233) .8556 (X_U3.N430319) .7199 (X_U3.N430701) 0.0000 (X_U3.N431153) .8556 (X_U3.N431299) .8556 (X_U3.N431415) 100.0E-06 (X_U3.N448013) 219.1E-06 (X_U3.N523713) 219.1E-06 (X_U3.N652534) 1.1530 (X_U3.N658624) .2000 (X_U3.N664581) .0372 (X_U3.N682208) 851.5E-12 (X_U3.PREVOUT) .0041 (X_U3.U1_DROP) .0920 (X_U3.VIN_INT)-47.67E-06 (X_U3.Vzz_INT) 219.1E-06 (X_U3.X_U17.1) 0.0000 (X_U1.U2_QB_ND) 1.0000 (X_U1.U2_RESET) 0.0000 (X_U2.CLAMP_TH) 1.0000 (X_U2.DRVA_MOD) 0.0000 (X_U2.INPUT_OK) 0.0000 (X_U2.VCC1_INT) 3.0000 (X_U2.VCC2_INT) -.8513 (X_U2.X_U676.1) 0.0000 (X_U2.X_U677.1) 0.0000 (X_U3.N1078460) 0.0000 (X_U3.N1078548)-34.54E-09 (X_U3.N1111214) 851.5E-12 (X_U3.N1112560) 0.0000 (X_U3.U1_EN_IH) .9000 (X_U1.COFF_ILIM) 41.58E-06 (X_U1.ISENSE_LS)-8.384E-06 (X_U1.N16822551) 1.0000 (X_U1.U1_ISENSE) 8.400E-06 (X_U1.U1_QISINK) 0.0000 (X_U1.U3_FBCOMP) 0.0000 (X_U1.U4_VIN_EN) 1.0000 (X_U2.INPUT_DEL) 0.0000 (X_U2.N16669580) 0.0000 (X_U2.N16669982) 0.0000 (X_U2.N16672528) 0.0000 (X_U2.N16781655) 12.0000 (X_U2.N16789976) 2.7000 (X_U2.N16816719) 2.1000 (X_U2.N16832250) 0.0000 (X_U2.N16839246) 1.2000 (X_U2.N16850890) 2.1000 (X_U2.N16850947) 1.0000 (X_U2.N16851003) 1.2000 (X_U2.N16855073) 0.0000 (X_U2.N17027842) 0.0000 (X_U2.N17110019) 0.0000 (X_U2.N17112053) 0.0000 (X_U2.N17113570) 0.0000 (X_U2.N17147754) 2.8554 (X_U2.N17157839) 1.0000 (X_U2.N17180339) .8545 (X_U2.N17180405) .0041 (X_U2.N17358601) .8545 (X_U2.N17450859) .8547 (X_U2.X_U30.my5) 1.0000 (X_U2.X_U30.qbr) 1.0000 (X_U2.X_U30.qqq) -.1393 (X_U2.X_U6.INM1) -.3000 (X_U2.X_U6.INP1) 0.0000 (X_U2.X_U6.INP2) .2000 (X_U2.X_U7.INM1) 12.8510 (X_U2.X_U7.INP1) 0.0000 (X_U2.X_U7.INP2) 0.0000 (X_U3.U1_EN_HYS) .5000 (X_U3.U1_VIN_OK) 0.0000 (X_U1.U3_VREF_RR) 107.0E-09 (X_U2.CLAMP_SIGB) 0.0000 (X_U2.X_U17.YINT) 0.0000 (X_U2.X_U18.YINT) 1.0000 (X_U2.X_U19.YINT) 0.0000 (X_U2.X_U20.YINT) 0.0000 (X_U2.X_U26.YINT) 1.0000 (X_U2.X_U30.qint) -.1393 (X_U3.U1_VREF_SS) 189.4E-12 (X_U3.X_U17.INM1) .3692 (X_U3.X_U17.INP1) 0.0000 (X_U3.X_U17.INP2) 0.0000 (X_U3.X_U1_U16.1) 0.0000 (X_U3.X_U1_U17.1) 0.0000 (X_U3.X_U4.YINT1) 0.0000 (X_U3.X_U4.YINT2) 0.0000 (X_U3.X_U4.YINT3) 1.0000 (X_U1.X_U1_U616.1) 0.0000 (X_U2.X_U30.myvss) 0.0000 (X_U2.X_U30.qqqd1) 0.0000 (X_U2.X_U676.INM1) 2.1000 (X_U2.X_U676.INP1) 0.0000 (X_U2.X_U676.INP2) 0.0000 (X_U2.X_U677.INM1) 2.1000 (X_U2.X_U677.INP1) 0.0000 (X_U2.X_U677.INP2) 0.0000 (X_U2.X_U678.Yint) 1.0000 (X_U1.U1_N16776085) 0.0000 (X_U1.U1_N16776383) 8.4001 (X_U1.U1_N16776519) 0.0000 (X_U1.U1_N16776659) 1.0000 (X_U1.U1_N16776683) 1.0000 (X_U1.U1_N16776729) 0.0000 (X_U1.U1_N16791512) 8.400E-06 (X_U1.U1_N16804692) 1.6000 (X_U1.U1_N16809401) 2.9900 (X_U1.U1_N16809741) 2.0000 (X_U1.U1_N16810788) 0.0000 (X_U1.U1_N16817941) 1.0000 (X_U1.U1_N16820806) 1.0000 (X_U1.U1_N16821918) -.0100 (X_U1.U1_N16821958) -3.4000 (X_U1.U1_N16822787) -.0100 (X_U1.U2_N16755126) 1.0000 (X_U1.U3_N16744464) 20.01E-06 (X_U1.U3_N16746684)-3.358E-18 (X_U1.U3_N16763426) 1.845E-06 (X_U1.U3_N16763446) 1.0000 (X_U1.U3_N16763508) 2.0000 (X_U1.U3_N16763538) 1.0000 (X_U1.U3_N16763566) 1.840E-06 (X_U1.U4_N16747027) 4.0000 (X_U1.U4_N16747033) 1.0000 (X_U1.U4_N16747121) 1.2500 (X_U1.U4_N16747127) 0.0000 (X_U1.U4_N16747163) 0.0000 (X_U1.U4_N16747195) 5.0000 (X_U1.U4_N16751419) 4.4000 (X_U1.U4_N16782096) 10.65E-06 (X_U1.U4_N16789606) .4000 (X_U1.U5_N16751216) 2.0200 (X_U1.U5_N16751262) 2.1698 (X_U1.U5_N16765173) 2.3000 (X_U1.X_U1_U7.YINT) 1.0000 (X_U1.X_U2_U6.YINT) 1.0000 (X_U1.X_U2_U8.YINT) 1.0000 (X_U1.X_U2_U9.YINT) 0.0000 (X_U1.X_U3_U1.YINT) 0.0000 (X_U1.X_U3_U2.Yint) 3.136E-15 (X_U1.X_U3_U3.YINT) 0.0000 (X_U1.X_U3_U4.YINT) 1.0000 (X_U1.X_U3_U5.YINT) 1.0000 (X_U1.X_U4_U5.Yint) 1.0000 (X_U1.X_U4_U7.Yint) 1.0000 (X_U2.GATEUPPERMOS) 0.0000 (X_U3.U1_N16777354) 2.1500 (X_U3.U1_N16777400) 2.254E-09 (X_U3.U1_N16777525) 2.254E-09 (X_U3.U1_N16777592) 0.0000 (X_U3.U1_N16777602) 1.1498 (X_U3.U1_N16782898) .0700 (X_U3.U1_N16803016) 0.0000 (X_U3.U1_PRE_EN_OK) 0.0000 (X_U1.U1_N167759170) 2.0000 (X_U1.U1_N167759390) 0.0000 (X_U1.U4_N167841540) 7.5000 (X_U1.X_U1_U631.my5) 1.0000 (X_U1.X_U1_U631.qbr) 1.0000 (X_U1.X_U1_U631.qqq) 210.2E-09 (X_U1.X_U2_U10.YINT) 1.0000 (X_U1.X_U2_U11.YINT) 0.0000 (X_U1.X_U2_U12.YINT) 0.0000 (X_U2.GATE_CLAMPMOS) .8554 (X_U2.GATE_LOWERMOS) .8554 (X_U2.UVLO1_DELAYED) .9878 (X_U2.UVLO2_DELAYED)-2.139E-27 (X_U2.X_U30.x3.YINT) 0.0000 (X_U3.X_U1_U16.INM1) 2.1500 (X_U3.X_U1_U16.INP1) 0.0000 (X_U3.X_U1_U16.INP2) 0.0000 (X_U3.X_U1_U17.INM1) .9000 (X_U3.X_U1_U17.INP1) 0.0000 (X_U3.X_U1_U17.INP2) 0.0000 (X_U3.X_U1_U19.YINT) 0.0000 (X_U1.X_U1_U603.YINT) 1.0000 (X_U1.X_U1_U616.INM1) 2.9900 (X_U1.X_U1_U616.INP1) 0.0000 (X_U1.X_U1_U616.INP2) 0.0000 (X_U1.X_U1_U629.YINT) 1.0000 (X_U1.X_U1_U630.Yint) 0.0000 (X_U1.X_U1_U631.qint) 210.2E-09 (X_U1.X_U1_U632.Yint) 0.0000 (X_U1.X_U4_U606.Yint) 0.0000 (X_U1.X_U4_U607.YINT) 0.0000 (X_U1.X_U4_U609.YINT) 0.0000 (X_U1.X_U4_U610.Yint) 1.0000 (X_U1.X_U1_U631.myvss) 0.0000 (X_U1.X_U1_U631.qqqd1) 0.0000 (X_U1.X_U1_U631.x3.YINT) 0.0000 **** Interrupt ****
