TPS23734: auxiliary power adapter
Part Number: TPS23734
A customer of mine needs to support an auxiliary power adapter in the voltage range of 9V to 57V. Can the TPS23734 support that when using a matching transformer?
VL
  • Hello Victor,
    Yes the TPS23734 can support a 9V-57V input -- we call this Wide-Vin in PoE.
    As you pointed out, the biggest factor to wide-Vin is the transformer.
    To use with the TPS23734, I would suggest option 2 in the following paper. This puts the adapter on the VDD-RTN to power the DCDC. Use the APD pin to disable PoE.
    If this post answers your question, please indicate so by marking this thread as resolved. Thank you.
    Michael P.
    Applications Engineer
    Texas Instruments
