Hi are using the TPS62135 in our custom board, and wanted to confirm how the PG control behaves with respect to fast transients on the output voltage?
The data sheet specifies these thresholds for Power good:
Does this mean that at worst case on IC the power good will fail if VFB exceeds -3%/+2% of the 0.7V level due to a transient condition?
Is there a trip time constant where the voltage must be exceeded for a certain duration prior to Power good being pulled low?
Is there any debounce protection on the power good line?
Can you provide input on what this PG Control block does in more detail?
