LM3532: Mismatched String Lengths: Use a separate voltage regulator fed with LM3532's Vout?
Part Number: LM3532
In the situation where the string lengths vary greatly such as 5 vs 3 (a difference of 6V), section 7.3.3 of the datasheet recommends using a separate supply for the shorter string(s). Would it be ok to feed a voltage regulator's Vin with LM3532's Vout?
regulator config
