Hello Experts,
I have question as follows. Would you please answer them?
1. For single-end sensing, SNS- terminal connects to AGND per the datasheet, correct? At this time, the datasheet mentioned "For single-end sensing, connect the higher FB resistor to a high-frequency local bypass capacitor of 0.1-μF or higher, and short VSNS– to AGND with shortest trace.". Where does the bypass capacitor connect? Does it connect to between FB-pin and AGND?
2. For single-end sensing, the capacitor of SS/REFIN is connected to AGND(SNS- pin), correct?
Fujiwara
