BQ27421-G1: BQ27421 terminate voltage higher than setting
Part Number: BQ27421-G1
Hi
The Terminate voltage is set to 3.3V. After several cycles of learning, it is found that the terminate voltage is getting higher and higher.
The first discharge cut-off voltage is 3.353V, SOC=1%, RM=0mAH;
The second round is 3.382V, SOC=2%, RM=0mAH;
The third round is 3.424V, SOC=2%, RM=0mAH;
The third round is 3.458V, SOC=1%, RM=0mAH;
After multiple rounds, the discharge cut-off voltage is 3.499V, SOC=1%, RM=0mAH
The Max Delta Voltage is 20mV, the RA table as below:
02.23
Ra表
02.24
Ra表
02.25
Ra表
Ra0: 89 Ra0: 89 Ra0: 89
Ra1: 89 Ra1: 89 Ra1: 89
Ra2: 100 Ra2: 100 Ra2: 100
Ra3: 131 Ra3: 131 Ra3: 131
Ra4: 125 Ra4: 125 Ra4: 125
Ra5: 146 Ra5: 146 Ra5: 146
Ra6: 189 Ra6: 189 Ra6: 189
Ra7: 224 Ra7: 224 Ra7: 224
Ra8: 213 Ra8: 213 Ra8: 213
Ra9: 218 Ra9: 218 Ra9: 218
Ra10: 309 Ra10: 309 Ra10: 309
Ra11: 358 Ra11: 358 Ra11: 358
Ra12: 705 Ra12: 705 Ra12: 705
Ra13: 1798 Ra13: 1798 Ra13: 1798
Ra14: 2871 Ra14: 2871 Ra14: 2871
Why the terminate voltage is getting higher and higher?
Waiting for your reply.
Star
